what is this sensor?
I recently found this sensor melted onto my header. It has a vaccum line that goes to the throttle body, and another vaccum line that use to go to my egr until i removed the egr and just plugged the line. The vaccum lines go right into this sensor, then the sensor has a harness that goes inside my fender. any help will be appreciated
Did it look like a small round can with vacuum lines across the top and a few wires on the bottom? If so its probly the purge valve going to the charcoal canister . When enough vapors collect in the canister it opens and allows them to purge into the throttle body to be used in combustion.
this is a random photo i found online, but its is the red vaccum line with a black 90 degree boot that goes into the top of throttle body, then travels down the side of engine(over valve cover in the convelute) into a round style sensor
jwog666
12-27-2021 08:09 PM
TfcCDR
09-14-2015 12:08 PM
