245/60R15 Tire Rubbing
Old 11-06-2012, 10:39 PM
90nSSMD
90nSSMD's Avatar
Default 245/60R15 Tire Rubbing
I have a 1990 GT, and I just recently went out and got some used tires to last me until I can afford an entire set of 4 new. I opted for 245/60R15 BFG Radials in the rear.
I did a lot of looking and asking around, and I was told 245/60 was the highest I could safely go on my stock 10 holes without rolling fenders, or removing quads. Some people told me 245/50, but the clearance in height was fine on the 60s.
I've run into an issue and I'm stumped:
The driver side rear tire sits barely behind the fender on the outer wall (maybe 2-3/10th's of an inch), however the passenger side rear tire is sticking OUT.
I live in the city, and there are a lot of bumpy roads, so naturally I have run into tire rubbing issues on the passenger side. I can't for the life of me figure out why the tire is sticking out so far though.
I'm really not a tire guru, and not the most mechanically inclined, so any help to diagnose the issue would be appreciated, thanks.
Pics below to show what I'm talking about:
90nSSMD is offline
Old 11-06-2012, 11:15 PM
mattdel
mattdel's Avatar
Either the car is bent, or the control arms are.
mattdel is offline
Old 11-06-2012, 11:22 PM
90nSSMD
90nSSMD's Avatar
Thank you as always for the swift reply Matt. I'll take a look at the control arms tomorrow when I get out of work.
Also while I'm taking a look at the control arms, is there a way I can check if the frame is bent? Any key spots to look at?
I would assume taking the car into the shop to get an alignment will give me a solid answer on a bent frame. I'd just like to be prepare for the worst case scenario before I have to go that route (even though that would be worst case scenario in itself lol).
90nSSMD is offline
Old 11-06-2012, 11:50 PM
mattdel
mattdel's Avatar
Not too sure how to accurately check for a bent unibody, never got involved in body work. Alignment is pretty much out of the question, the way it sits will never allow it to happen.
mattdel is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: 245/60R15 Tire Rubbing
