Help with engineering stupidity
Old 11-18-2012, 11:30 AM
Duncan_GT
Duncan_GT's Avatar
Default Help with engineering stupidity
Just installed the 1" spacer and Trickflow R-series upper intake. The spacer came with a longer hardware kit (not sure if that has anything to do with the problem).
Pic 1
I believe this is as far as the bolt will go, I didn't want to keep torquing it and strip the aluminum all to hell. Absolutely no clamping pressure.
Pic 2
This is probably just an overlooked design issue. How the hell am I supposed to get the nut on the stud? This one isn't as bad, I'll probably cut the stud down a bit.
I'd like to get some suggestions to fix this. This is the crap thats most irritating.
Duncan_GT is offline
Old 11-18-2012, 04:51 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
cut stud/ bolt in both instances, or use washers on the long bolt and or grind a little of the aluminum away on the intake and trim stud for a better access
mjr46 is offline
Old 11-18-2012, 05:56 PM
94redGTConv
94redGTConv's Avatar
take a grinder and fabricate it won't hurt anything
Posted from MustangForums.com App for Android
94redGTConv is offline
Old 11-21-2012, 06:30 PM
capri debris
capri debris's Avatar
Call the guys at Trick Flow, I've talked with different people there many times and they are all really cool. Tell them what's going on and send them some pics so they can see that the hardware they are supplying isn't working... and let us know what they have to say about this problem.
capri debris is offline
Old 11-21-2012, 07:38 PM
Bubba 95SN
Bubba 95SN's Avatar
Have put spacer on and seems one bolt would work in just one hole...Might have trimmed, do not remember. Stud, held upper up and started the nut, is 12 point.
Bubba 95SN is offline
Old 11-21-2012, 08:04 PM
mattdel
mattdel's Avatar
Am I the only one noticing that the pictures appear to say that the spacer isn't installed? Unless the spacer is made of aluminum and has the exact same appearance as the upper intake. Look behind that plug wire, there is no spacer installed there.
mattdel is offline
Old 11-21-2012, 09:27 PM
Duncan_GT
Duncan_GT's Avatar
Thats my garage light reflecting off the aluminum. The spacer is just below that, its painted blue (its hard to see in that pic). Ill take another pic of it tonight. My buddy said he had the same problem w that stud, and just to lift the intake enough to get the nut in there and start tightening the nut. Its the center bolt that I'm having the real trouble with
Old 11-21-2012, 09:39 PM
Venomantidote95
Venomantidote95's Avatar
On the stud raise the plenum and start the nut then it`ll clear idk what that bolt is that high for i have installed a couple of these and didnt have that problem.
Venomantidote95 is offline
Old 11-22-2012, 02:50 PM
89fiveeight
89fiveeight's Avatar
No clue, but it looks like you got your paint dilema figured out lol
89fiveeight is offline
Old 11-22-2012, 04:16 PM
Duncan_GT
Duncan_GT's Avatar
Yea lol it looks good!
Quick Reply: Help with engineering stupidity
