my 89 fox is over cooling itself, idea's? - MustangForums.com
Old 12-02-2012, 02:56 PM   #1
ScreamnV8
ScreamnV8's Avatar
Default my 89 fox is over cooling itself, idea's?
Hey all so my car has been running cool for a while now, being constantly at 120 degrees even when driving for a while, it only climbs if i idle for about 20 minutes and it goes to 160 max.
I have changed the heater core, thermostat and the radiator cover. No leaks have been seen or anything of that sort, i do blow out kind of thick white smoke when cold until it warms up but i also have no cats .
It never overheats nor does it get even close and takes about 15 mintues to warm up the heater temp to. any idea's? And should i be expecting any bad effect from this?
ScreamnV8 is offline   Reply With Quote
Old 12-02-2012, 03:08 PM   #2
rmodel65
Yukon Cornelius
rmodel65's Avatar
are you going by the gauge in the car?? or do you have an aftermarket gauge
rmodel65 is offline   Reply With Quote
Old 12-02-2012, 03:11 PM   #3
ScreamnV8
ScreamnV8's Avatar
it is an aftermarket gauge in car and on radiator cap, cap will say about 80 degrees while gauge in car says 120's or so.
So it shows that the radiator is staying cool but way to cool.
Old 12-02-2012, 03:12 PM   #4
darkmach1
darkmach1's Avatar
Change your thermostat, get a MR gasket or Stant 180 or 195. I've personally find that engine temp hard to believe.
darkmach1 is offline   Reply With Quote
Old 12-02-2012, 03:18 PM   #5
ScreamnV8
ScreamnV8's Avatar
Its a brand new stant 195 degree i believe with new gasket. All should be where it is, but isn't. ?
Old 12-02-2012, 03:39 PM   #6
darkmach1
darkmach1's Avatar
I can't see a motor running at 120 degrees even with a stuck open t-stat unless there are several cyls not firing.
Old 12-02-2012, 04:12 PM   #7
mattdel
mattdel's Avatar
Would probably take a seized fan clutch along with stuck open thermostat and multiple non-firing cylinders
mattdel is offline   Reply With Quote
Old 12-02-2012, 09:05 PM   #8
ScreamnV8
ScreamnV8's Avatar
It runs a little sluggish but really doubt that it is misfiring, it is odd i know. i have yet to come across anything like it. I DO how ever have a vented hood which i have had in the past before and it has cooled some but nothing to this extent?!?! Unless the new stat is already stuck opened. i am at a real loss.
Old 12-02-2012, 11:19 PM   #9
mattdel
mattdel's Avatar
If its in backwards, the water pump pressure will open it right away.
Old 12-03-2012, 10:08 AM   #10
ScreamnV8
ScreamnV8's Avatar
Quote:
I'm pretty sure it was installed correctly, the top (triangle part) is pointin towards the radiator area.
2007 starts then stalls piotrek53 4.0L V6 Technical Discussions 3 10-13-2015 07:54 PM
I'm selling my Trans Am. GStam66 Off Topic 42 09-26-2015 11:06 PM
Hi Glocker23 New Member Area 6 09-23-2015 09:19 AM
01 Mustang Overheating :( MusicCity615 General Tech 7 09-12-2015 08:05 AM
Opinions regarding 2015 Base Mustang GT w/19' wheels & Ford Racing Handling pack? mungodrums Suspension 0 09-07-2015 08:22 PM
