95 amp vs 130 amp
95 amp vs 130 amp
So I noticed that my fox has been sucking a lot of power at idle due to my upgraded sound system and electric fan; especially with the headlights on. With that being said I'm in the market for a new alternator (being that mine is still the stock 75 amp).
I was wondering if ya'll think the 95 amp would be sufficient enough to power my fox (would be an easy install since its a direct fit) or if I should go big and get the 130amp 3G conversion.
If I do go with the 130 amp I just wanna make sure there's no such thing as too much juice running through its veins ie would there be any adverse side affects to running almost double the amperage in it?
Thanks.
Thanks.
There are no downsides, the alternator only pushes out as much power as needed. Nothing more and hopefully nothing less. I would suggest getting the 95W amp if you don't plan on doing anything else of electrical to your fox
breaking
10-02-2015 01:27 PM
