T5 input shaft question
12-16-2012, 05:51 PM
So while installing my t5 into my 90 5.0 the pilot bearing has play, realizing its a 4cyl trans... What pilot bearing will fit or can I swap out input shafts? Thanks
12-16-2012, 06:41 PM
Also it shifts amazing. No grinds.
12-16-2012, 06:50 PM
im not sure inputs are interchangeable. know that a 4 cyl t5 is NOT world class, while a 8 cyl T5 from 1985 and newer IS world class
i have one i can sell you CHEAP....i probably have 2
12-16-2012, 06:53 PM
Yeah it's a borgwarner. I read somewhere that there a pilot bearing I think from a 80s ranger that fits but I cannot find where I read that
12-16-2012, 06:59 PM
they are all borg warners, that trans is rated for something like 160 hp depending on year,yes there is a pilot bearing that fits....but are you sure you wanna do this ?
12-16-2012, 07:01 PM
Yes It's already in the car, ill get a backup trans at tax time.
12-16-2012, 07:06 PM
Pilot bearing out of a 84 diesel ranger works. As long as you don't go ripping and tearing on it, it should last until you get a new trans.
I'm not sure if the input shafts will change out in the 4cyl trans but I know they will in the v6 trans.
12-16-2012, 07:10 PM
Tried the ranger bearing and didn't work, it was too big for the input shaft.
The trans has byn rebuilt in recent years, don't know the specs
12-16-2012, 09:47 PM
Hmm well then I don't know which direction to point you in man... sorry, but if you figure it out report back so we have the info for the issue.
12-16-2012, 09:51 PM
Will do. We are completely lost, the ranger and 4cyl bearings are the same part #.
