Also having starting problems...
Old 12-20-2012, 04:12 PM
dawson1112
dawson1112's Avatar
every one of those codes is circuit related. or otherwise the ecm is seeing unexpected voltages at those sensors all on the voltage below expected readings.
Check for a short or loose ground someplace.
23 - TP sensor out of self-test range
32 egr position sensor is below closed voltage.
67= neutral/drive switch open or the ac was on
84 - EGR vacuum solenoid circuit failure
dawson1112 is offline
Old 12-20-2012, 04:33 PM
1991 Mustang GT
1991 Mustang GT's Avatar
it was my TPS - fired right up
1991 Mustang GT is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
dalefrancis88
09-11-2015 07:15 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Also having starting problems...
