which throttle body?
i've got a 94 GT mainly stock with a bbk c.a.i. and flowmasters and deleted smog and ac. I plan on getting an edelbrock intake manifold, headers, and heads among other things. So my question is until i get my mustang to the heavily modified stage can i get a 75mm throttle body without having any adverse affects or should i just get the 70mm? Also i am keeping it NA so would i still need a 75?
Since you are not changing out your MAF, you will be fine. Eventually, you will want to change this out because i believe the 75mm TB will be larger then your MAF. So your MAF is essentially creating a bottleneck, but this is another post...
