BBK ssi intakes
#21
You should always disconnect the battery when working on the car I was just wondering if you did because it will need to relearn certain things. Any time I have my battery disconnected for more than a few hrs the car idles like crap for the first few cold starts.
#22
Ok. I drove it today and seems better. Did the base idle reset after having the battery off.? I think i will check the tps voltage and reset my idle because when i turn on car or come to a stop the car idles at 600. Does not turn off but just idles low. Has to be the base idle im thinking..?
#23
I don't think 600 rpm is to bad as long as the lope is gone. And its not burning your eyes from the exhaust. Mine would lope like it had a huge cam in it and would be so rich it burned your eyes. I think my idle is set around 700 right now. Id like to have mine idle closer to 600 but I have underdrive pullys and that low an idle kills my power steering and alt .
#24
OK.. maybe its just me because all my stang have idles above 700., Just not use to the 500-600 rpm range, Sounds way too quite to me. Well it does smell a bit richer than before..? Will an out of range TPS do that?
#25
#27
Well Maybe people are scared to buy them because of the bad rep some people gave them, like how it wont fit under stock hoods. Im not a pro and i cant say that ive tried other aftermarket intakes to compare but i gotta say this one woke my car up!
#29
I know.. aint that sumthin. LOL. I knew it was to good to be true when i installed it all, and what i mean by to good to be true i mean it was a very easy install.
update., I tried to reset the idle but i think i failed because i still have to have the idle screw adjusted alot to get to 750rpm's. I also adjusted the tps and that did need adjusting. Drove the car to work and is running better but at idle it isnt as smooth as before but close. At a cold start of have to give the car a pump of the gas to catch idle which bothers me a little. Iam almost at the point where iam going to tear it all down and re-install everything again but my fingers hurt LOL.
