Spoiler leak
Old 12-29-2012, 06:53 PM
Jville808
Jville808's Avatar
Default Spoiler leak
i just bought a virgin 93 GT. It has one of those whale tale spoilers on it. that thing is history the moment I have the money for a cobra spoiler, but in the meantime i need to repair a leak into the trunk that comes from one of the screws/bolts. One of the holes is big enough to see with the spiler on so of course water is finding its way right through it and into the trunk. there was a little rust on the top of the hatch near the hole but its been repaired (i saw pics from the seller of the prep done to the car prior to paint). the inside of the hatch looks good and the trunk, other than the wet carpet looks good too. The hole that is visable is a drilled hole, not a rusted out spot. i imagine some of the other holes are exposed as well, just not as visable.
Anyways, I did a search on here and noticed this problem mentioned in things too look out for when buying one of these cars, but no mention of anyone that actually has that problem and how to fix it. So, any advice on what to do so I can enjoy a dry trunk and prevent further damage to the hatch?
I'd like to avoid silicone as this is going to be a temporary fix until I replace the spoiler. I'd also like it to look clean and don't want to look at silicone seeping out the sides of the spoiler. Do new spoilers come with some sort of weatherstripping beneath them to cover the holes? What is that and where do I find it? I was thinking a butyl tape (it would have to be approx. 3/4" wide) but that could get messy. I've seen 3m tapes, but they're adhesives and I dont want to anchor this thing down. What's the tape called found inside autos thats black, thin and rubbery, kinda like dynomat? Any other suggestions along those lines?
Thanks in advance!
Jville808 is offline
Old 12-29-2012, 07:07 PM
bluebeastsrt
bluebeastsrt's Avatar
Find a sheet of rubber and cut some gaskets to fit the shape of the spoiler pedastal. But a little sealant isn't going to hurt. It'll peal right off when needed.
bluebeastsrt is offline
Old 12-29-2012, 07:36 PM
Jville808
Jville808's Avatar
the problem with silicone, and possibly the rubber is this one hole is slightly visable. the spoiler doesn't cover it completely. silicone would be visable and the wing won't come down on the entire hole to create a watertight seal. that's why I was thinking of some sort of dynomat type material, adhesive on 1 side that can be cut to the shape of the wing and seal all the holes. it would be slightly visable as well, so it'd have to be in black and thin.
Old 01-01-2013, 04:15 AM
94redGTConv
94redGTConv's Avatar
Be creative, and it'll come to you how to fix it.
Posted from MustangForums.com App for Android
94redGTConv is offline
Old 01-01-2013, 05:26 AM
dawson1112
dawson1112's Avatar
Im guessing your car is black?
Use some ultra black rtv gasket sealer. fill the holes and smooth it with your finger . It will peel of later and you wont even notice it on the black paint.
What ever you do I advise you to do it soon the trunks on these cars a notorious for rusting out because of water leakage.
dawson1112 is offline
Old 01-01-2013, 09:12 AM
ALMOST STOCK
ALMOST STOCK's Avatar
I'm the original owner of my 89 and when I removed my rear spoiler for paint there was a thin white foam gasket under it.
ALMOST STOCK is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Spoiler leak
