I need help... please read
To see if the distributor was installed correctly, remove the #1 spark plug and the coil wire so it won't try to crank. Put a finger over the spark plug hole and have someone in the car bump the starter slowly until the compression stroke pushes your finger off the spark plug hole, that' TDC. The rotor button should now be pointing to #1 wire on the cap. If it's not rewire it like this...http://www.fiveohinfo.com/fox/ignition.html
Update: The original shop was open today to my surprise. I got the car towed in and they fixed it. The did what I really didnt wanna do(especially since I do not have a garage and its snowing today) and reset the distributer and timed it. Running great again! Thanks again for all the help and I if you do not see me around I wanna wish you all a Happy New Year! =)
Matt's 95 Stang
10-05-2015 07:16 AM
09-27-2015 03:16 PM
