Vac lines question
Vac lines question
86 GT
Hey guys whats up, I need to find out which vac lines I need hooked up.
Car has no smog pump no AC and the lines are a mess, I have DL'd the routing diagram I just need to know which lines I need to run and which I dont. The black tree is there on the firewall with nothing hooked up to it engine will start but will not idle at all.
I have been putting this off since before christmas and I need to get her running. ( I got the car this way )
Thanks in advance if anyone can lead me in the right direction.
Dean
Dean
MAP sensor, Brake booster, fuel pressure regulator, EGR.
Technically speaking, those are the only ones required. You also have heater control vacuum, speed control(cruise), smog pump solenoids(TAB/TAD), and probably some others I'm forgetting.
EGR does not appear to be connected can this be blocked off or removed as well?
Man, thanks for responding so fast!
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
