Camshaft thrust plate
Is it worth upgrading the cast iron camshaft thrust plate with the Ford Racing steel one? I'm going to order a new timing set that has the torrington bearing and didn't know if I should install it with the stock thrust plate.
Yep, you'll need a dial indicator to do this. They aren't as expensive as you may think. If you take any kind of care of it, it'll last for ever.
I've got one that I've been using for 35+ years.
It's also more useful than you think too..........
How do you measure for it then as far as getting the cam to move back and forth?
Is the plate thick enough to countersink? I am using grade 8 bolts on the plate, and if I recall, the hex head of the bolt is almost as thick as the plate. I didn't want to start boring the bolt holes and only leave myself a tiny bit of material that takes the torque of the bolt (if that makes any sense). I'll have to see if Lowe's carries grade 8's with an Allen head
you can't use the stock bolts with the torrington set up as it rides against the plate and will intefere with the heads, IIRC THE torrington set up comes with the proper countersunk headed bolts, all you do is sink it with iirc a 82 degree countersink bit which I got at home depot and presto, all done!!
maestro1024
09-21-2015 02:40 PM
