piston to valve clearance question.
Old 01-15-2013, 11:17 AM
Gt 5 point 0
Gt 5 point 0's Avatar
Default piston to valve clearance question.
Over the winter im doing a top half engine rebuild. Stock 302 bottom half. Its a 95 gt. Ill be putting on Trick flow track heat 185cc heads, track heat intake, and stage 2 cam. Is the piston to valve clearance ok? or is something not going to be right. I wanna ask that before i tear into my motor casue if somethings not going to work ill just leave how it is.
These heads.
http://www.latemodelrestoration.com/...Aluminum-Heads
please let me no and ask any questions if you need further details. thank you guys!
Gt 5 point 0 is offline
Old 01-15-2013, 11:40 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you'll have to check it, even if one build clears doesn't mean another will
mjr46 is offline
Old 01-15-2013, 12:11 PM
Gt 5 point 0
Thanks mjr46, Its easy to do so looks like thats what i will do.
Old 01-15-2013, 12:18 PM
Autotech
Autotech's Avatar
You should be fine with the stock pistons. It is always good to check and adjusting your push rod length is always an option.
Autotech is offline
Old 01-15-2013, 12:23 PM
mjr46
mjr46's Avatar
with a twisted wedge, the radial will be what you need to look at
mjr46 is offline
Old 01-15-2013, 11:43 PM
tinman
tinman's Avatar
Make sure you keep .100" if it's a street engne.
.080" if it's race only with good valve springs..............
tinman is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
svfetter
10-05-2015 11:39 AM
EASTIDEE123
09-14-2015 03:52 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
Quick Reply: piston to valve clearance question.
