Injector and Maf size
Dont know what all the heads have. They are being very secretive about them. I was told they will be released in March.
The rotating assembly will be lightened/balanced race parts. I also plan on having 1.6 rockers topped with a stud girdle. Should be able to rev it to 7-7.5K and be okay.
Unless I get a 351 upper then a 75mm throttle body is all I can run since the 302 is only cast for that size. The 351 can take a 90mm TB.
What about the MAF?
What about the MAF?
I think it will bolt up. Ill have to double check it. Would a 90mm TB be overkill? Accufab also makes an 80mm and 85mm.
Just checked and Summit sells a complete intake kit for a 5.0 with the 90mm TB bore.
10-09-2015 03:27 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
