Injector and Maf size
Old 01-26-2013, 05:25 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Default Injector and Maf size
Im putting together a 331 stroker with 11.5:1 compression along with Trick Flow heads and intake. What size injectors and MAF do I need? I contacted Trick Flow about heads and was told a 75mm Throttle body will be okay. Ill be installing a Glenn's Performance fuel system and some JPC Racing fuel rails.
Heads: Trick Flow 11R
Intake: Trickflow R-series
Throttle body: Accufab 75mm with EGR delete
Let me know if any more info is needed.
Boss_Hotrod is offline
Old 01-26-2013, 06:13 PM
Duncan_GT
Duncan_GT's Avatar
Do you know your expected/estimated horsepower? Are you going to run any boost?
Duncan_GT is offline
Old 01-26-2013, 07:28 PM
Boss_Hotrod
No boost. I thinking/hoping to be close to 500 hp on motor.
Old 01-26-2013, 07:47 PM
Mike T
Mike T's Avatar
What cam are you running with 11.5 compression?
Mike T is offline
Old 01-26-2013, 07:56 PM
Boss_Hotrod
Not sure just yet. Still have to call Comp and get something figured out. Id like about a .550 lift cam.
Old 01-26-2013, 08:21 PM
Mike T
Mike T's Avatar
You're probably going to need the best starter money can buy.
Mike T is offline
Old 01-26-2013, 08:23 PM
Boss_Hotrod
Haha, Ive already got one that is supposed to start a 15:1 motor. Stocker would quick working when it got hot so I upgraded. Car is already built for the motor too. Once it goes in she'll be badass.
Old 01-26-2013, 08:31 PM
Mike T
Mike T's Avatar
Yes sir, it'll be one quick pony for sure.
Mike T is offline
Old 01-26-2013, 11:56 PM
89blackonblack
89blackonblack's Avatar
u may need 42s
89blackonblack is offline
Old 01-27-2013, 08:02 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Originally Posted by Boss_Hotrod
\ I contacted Trick Flow about heads and was told a 75mm Throttle body will be okay. .
LOL, no matter what size motor, 302, 331, 347, 363,408, ect ect they always recommend 75 and that's it, ever noticed trick flows tech line is the same as summit's............you want to make 500 as you state, don't bottleneck it.....also you don't mention cam??? valvetrain components will be key, before buying the heads I'd research and see if it's the standard heavy **** junk that comes on them, IMO, lightweight yet durable components are key for getting the most out of the combo.
mjr46 is offline
Quick Reply: Injector and Maf size
