Running rich, popping through intake, stalling, & running shuglish
Old 02-10-2013, 07:03 PM
Mike T
Mike T's Avatar
85-Canister Purge Solenoid circuit failure. Dawson beat me to it.
Mike T is offline
Old 02-10-2013, 07:17 PM
RNH524
RNH524's Avatar
Is that anything I should be concerned about ? If so how do I go about fixing that problem or checking for it ?>
RNH524 is offline
Old 02-12-2013, 08:25 PM
RNH524
RNH524's Avatar
So I replace the TPS and cant adjust it to go under 1.30 ?? Also I think I found out and hopefully the reason to this and my regulator is leaking so going to eliminate that tomorrow.
RNH524 is offline
Old 02-12-2013, 08:42 PM
dawson1112
dawson1112's Avatar
If you cant get your tps to go below 1.3v I suggest you check your throttle stop screw , someone may have turned the idle way up at one point to keep it running.
If you have to turn the throttle stop srew more than 1 1/2 turns before it looses contact with the throttle its turned up to much.
You can back it off till it is not making contact then insert a .010 feeler gauge between the stop screw and throttle plate. Turn the screw until it just makes contact with the feeler , remove the feeler and turn the screw an additional 1 1/2 turn.
Now check your tps voltage.
dawson1112 is offline
Old 02-15-2013, 09:05 PM
RNH524
RNH524's Avatar
So I just adjusted my TPS and changed the fuel filter, responding a lot better now. Still doesnt stay running, it seems like it wants to but still stalling out. Another thing is when I give it gas to keep it running my check engine light will come on than it will go off then keeps coming back on (Never did that before). Also when I try to hold it at a steady RMP it will drop RPMS and sometimes jump around but mainly just drops. I didnt get a chance to get to my regulator so its still leaking a little bit. Would that cause this to do it? If there a way to check to see if a regulator is bad or not ? I checked my vacuum to it and that was clear of gas and the smell of gas.
RNH524 is offline
Old 02-15-2013, 09:25 PM
89fiveeight
89fiveeight's Avatar
Does the cel flash constantly, or just turn on and then go back off
89fiveeight is offline
Old 02-15-2013, 09:41 PM
RNH524
RNH524's Avatar
It will come on stay on for a bit than turn off than come back on. No constant blinking, no pattern or anything like that to it.
RNH524 is offline
Old 02-19-2013, 04:51 AM
RNH524
RNH524's Avatar
Solving the problem! Converting to carb!
RNH524 is offline
Old 03-29-2013, 11:24 PM
samltheriault
samltheriault's Avatar
egr i would think. also check ur brake booster and any other vacuum lines u got. i like the carb joke though. haha... please tell me its a joke.
samltheriault is offline
Old 03-30-2013, 03:25 AM
dawson1112
dawson1112's Avatar
That sounds a bit extreme lol. Carb conversion is something I would only consider If I was swapping from a 4 or 6 cylinder to a v8.
When you checked your timing, did you verify top dead center on the #1 cylinder? Its possible that the harmonic balancer has spun the outer ring and you may think its in time when using a light. I would bring the #1 up to tdc using a wood dowl, then look at the harmonic balancer If its not on 0 then it spun.
Granatelli Sales
01-20-2020 12:34 AM
Nick Oliver
10-17-2018 04:22 AM
Luke9222
09-04-2015 06:46 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Running rich, popping through intake, stalling, & running shuglish
