Question about draining fluids
Old 02-13-2013, 07:26 PM
rockett_7
rockett_7's Avatar
Default Question about draining fluids
Ok, so I bought an older 302 and it was locked up, in order to unseize it I created a concoction of ATF, pb blaster, wd40 rust removal soak, and deisel fuel, dumped it in the cylinders and let it set for a couple of days. BAM! It got the motor unlocked. Now that all that crap has been sitting in the pan the last week or so, Im getting ready to attempt to start her up. what should I do about cleaning all that crap out?
Just drain it?
Seems like all some of that could be harmful if I just drained it, changed the oil and tried to start it.
Any suggestions?
rockett_7 is offline
Old 02-13-2013, 07:34 PM
Mike T
Mike T's Avatar
Pull the spark plugs and push it out with the starter. You do realize the rings are probably stuck, don't you.
Mike T is offline
Old 02-13-2013, 07:37 PM
rockett_7
rockett_7's Avatar
I'm not entirely sure what all is going on under there. I've turned the motor a full rotation and its building compression. Other than that, I'm not sure what else to check :/
Old 02-13-2013, 07:49 PM
Mike T
Mike T's Avatar
You softened up the rust that was in the cylinders and used the compression rings to scrape it off. You have to decide to rebuild it or try to crank it as is.
Mike T is offline
Old 02-13-2013, 07:55 PM
rockett_7
rockett_7's Avatar
At this point Im going to try to crank it as is. I was just curious as to what precautions, if any, I should or could take when draining that combination of chemicals, short of just changing the oil.
Old 02-13-2013, 08:16 PM
FrostByte
FrostByte's Avatar
Change the oil again after warming oil up to flush out all those solvents.
FrostByte is offline
Old 02-13-2013, 08:20 PM
rockett_7
rockett_7's Avatar
That was my plan, thanks guys
Old 02-13-2013, 08:23 PM
Mike T
Mike T's Avatar
Push it out the spark plug holes with the starter and put some gas in a squirt bottle, put that in the cylinders, push that out, should clean it up pretty good. That concoction doesn't sound to combustible to me.
Mike T is offline
Old 02-13-2013, 09:07 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
drain the oil, push the crap out of the cyl's with the starter/plugs removed then reinstall all and fire it up or at least try too
mjr46 is offline
Old 02-13-2013, 11:27 PM
tinman
tinman's Avatar
^^^^^^^^^^^Sounds best to me ^^^^^^^^^^^^^^^^^^^
tinman is offline
Quick Reply: Question about draining fluids
