kittycurran
Old 02-18-2013, 01:20 PM
dowcurran
dowcurran's Avatar
Default kittycurran
just got a 1989 gt it runs ok but hesitates from 1st gear to 2nd after that it seems to be ok although i'm being told that it is nowhere near running right.the motor seems to to running ok is it possible the catalytic converters are clogged or something else?
dowcurran is offline
Old 02-18-2013, 03:27 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
no.......if cats were clogged most likely situation would not go away after 2nd gear, sounds like a secondary ignition component issue......ie...plugs, cap, rotor/wires
mjr46 is offline
Old 02-18-2013, 05:43 PM
Mike T
Mike T's Avatar
Check and see if you're getting any codes. Here's how to do it... KOEO http://oldfuelinjection.com/?p=13 and KOER test...http://oldfuelinjection.com/?p=94
Mike T is offline
