5 lug conversion question
I know... I know.... I have looked and i'm having a hard time finding the answer.
If I put this kit on my Mustang will I be able to run most 5 lug wheels? or am I limited to certain ones? Will any other wheels fit other than what is listed?
http://www.latemodelrestoration.com/...Conversion-Kit
Thanks!!!
Thanks!!!
the center of the hub will stick through most of the aftermarket wheels unless you run 94-95 17 inch wheels...
with that said you can buy 2 rotors for a lincoln mark 7 and 2 ranger axles(do a search i think its left side you need) and the ranger drums and convert to 5 lug for real cheap that is all that kit is...
I just went through all this to run fr500's. I ended up buying a brake and five lug conversion setup from mpsautosalvage. Paid around $1200 for a Cobra setup, but they have the non-cobra setup with everything you need for like $800.
for 800$ id just buy a 94-95 v6 car off craigslist and swap everything over and get rear disc brakes to boot...you can find sixxers for like 400-550$ take what you want put your stock parts on the sn95 and sell it bamm free brake conversion
Hit up a upull junk yard. I paid $20 each for ranger axles at a upullandpay salvage yard and found on CL complete front spindles, hubs, rotors and calipers from a new edge for $80. If you lived closer I have the ranger axles still because I never installed them and instead went new edge disc brakes all around.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
