Crankcase pressure too high?
Old 03-11-2013, 12:00 AM
Atomic
Atomic's Avatar
Lightbulb Crankcase pressure too high?
Hi all, I have had many headaches over this problem, and trying to find a solution of course has only made them worse.
I have an '88 5.0 with 99,000 miles on it. It was supercharged about ten years (5k miles ago) and this past summer I finally got around to getting bigger injectors to fix the air/fuel ratio.
This is my question. Will the higher pressures of the fuel and air inside the engine lead to higher oil pressure in the crank case? I'm taking a shot in the dark on this one, because I have a very serious oil leak. Actually, I'm losing about a quart of oil every 60 miles and need to keep some in the trunk whenever I take it out.
My sneaking suspicions are that it's a high oil pressure causing the rear main seal to spurt oil (I never looked too close to it at idle, but my garage floor is a mess of stains because of this).
Looking for anybody who has/has had this problem before, or if anybody can tell me what's going on.
Atomic is offline
Old 03-11-2013, 01:23 AM
tinman
tinman's Avatar
Any coolant in the oil?
I'd run a compression test just to make sure of what it is, all the cylinders should be within 10% of each other..........
tinman is offline
Old 03-11-2013, 03:49 AM
dawson1112
dawson1112's Avatar
Do you have any idea what your current oil pressure is? Its possible that you just need a new rear main seal. If you don't have an oil pressure gauge capable of giving you a accurate reading I suggest getting one . Normal pressure should be somewhere in the 40-60 psi range. Have you ever replaced the pcv , if not it could be plugged , or the screen under it is plugged . If you have no crankcase ventilation this would cause oil leaks in the seals.
dawson1112 is offline
Old 03-11-2013, 06:52 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check pcv if it is fine, replace the rear main seal and any other leaking gasket, 20+ year old car and gaskets and rubber become brittle =fact
mjr46 is offline
Old 03-11-2013, 08:45 PM
uedlose
uedlose's Avatar
=fact =fact I think MJR46 might be on to something here
uedlose is offline
Old 03-12-2013, 10:15 AM
Atomic
Atomic's Avatar
In response to an earlier post, no coolant in the oil and I don't have reason to believe I'm burning oil either. Thanks for the help guys, as soon as I pull the cover off it I'm going to check all the seals. Kind of had a "duh" moment here. I had a friend of mine tell me about a part called a breather, do you all think that might help? Seems like if that does the trick then it's a heck of a lot easier than trying to access the rear seal.
Atomic is offline
Old 03-12-2013, 10:16 AM
Atomic
Atomic's Avatar
Also, it's leaking directly onto the exhaust manifold if that gives any more clues.
Atomic is offline
Old 03-12-2013, 10:53 AM
Duncan_GT
Duncan_GT's Avatar
Do your valve covers accept a breather? Otherwise you'll have to modify and punch a hole in one, if not both, of yours.
Duncan_GT is offline
Old 03-12-2013, 04:05 PM
dawson1112
dawson1112's Avatar
If its leaking onto the exhaust manifold I doubt its the rear main seal , more than likely the valve cover gasket is bad. I guess you need to trace the leak back to its source.
CS2007
06-25-2019 09:45 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: Crankcase pressure too high?
