NAME THESE WIRES
Old 03-11-2013, 06:35 PM
boosted AWD
boosted AWD's Avatar
Default NAME THESE WIRES
1. Can you tell me which wire(s) is/are supposed to send power to the TAILLIGHT (not the brake light): (bonus question, name each wire.)
2. WHAT is this thing and what should it be plugged into??:
3. WHERE ARE THESE GUYS SUPPOSED TO BE GOING? (two pics):
4. WHAT IS THAT RED WIRE DOING AND SHOULD IT BE THERE??:
5. THIS TAILLIGHT LOOKS GOOD RIGHT???
6. IS THIS THE WATER TEMP SENDER FOR THE GUAGE??
7. DOES THIS NEED TO BE CHANGED??:
boosted AWD is offline
Old 03-11-2013, 07:44 PM
Mike T
Mike T's Avatar
Picture #3, this is used for the KOEO/KOER test to check for codes. They don't go anywhere. They are there when needed.
Mike T is offline
Old 03-11-2013, 11:18 PM
tinman
tinman's Avatar
Picture#5 It looks like a good bulb to me but the base could be corroded, then it 'no workee'.
tinman is offline
Old 03-12-2013, 10:02 AM
boosted AWD
thanks for the responses so far guys!
Old 03-12-2013, 11:10 AM
BabyGT
BabyGT's Avatar
2 looks like some kind of temp sensor and 4 looks like a fuse blew and they jumped power from another socket?
BabyGT is offline
Old 03-12-2013, 11:15 AM
mustangsneverdie
mustangsneverdie's Avatar
Pic number 2 is your act (air charge temp) sensor. It screws into the lower intake around the 1st and 2nd runner.
mustangsneverdie is offline
Old 03-12-2013, 11:47 AM
boosted AWD
Does this one look like it needs to be replaced? how does it effect the car not being plugged in?
Old 03-12-2013, 03:06 PM
Bubba 95SN
Bubba 95SN's Avatar
Brown wire is for tail lights and the black is for ground. Fuel pressure regulator...hook up fuel pressure gauge, remove red hose pressure should go 35 to 40 psi.
Bubba 95SN is offline
Old 03-12-2013, 04:15 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
3 is the act and screws in the lower intake for a fox, 6 is for the gauge in the car
mjr46 is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: NAME THESE WIRES
