What spark plugs and what gap should I run
Old 03-24-2013, 11:20 PM
chrstphrfenton
chrstphrfenton's Avatar
Default What spark plugs and what gap should I run
I have 91 Coupe with a 327 stroker with edelbrock performer heads and vortec supercharger (the small boost one 5-6psi)
I know edelbrock recommends champion RC12YC but is that good for my combo or should I run somthing else and what gap any suggestions are greatly appriciated thanks.
chrstphrfenton is offline
Old 03-25-2013, 04:35 PM
uedlose
uedlose's Avatar
I just run old copper autolites 2 heat ranges colder then what they recommend as far as gap I would start at .030 if you get spark blow out then close them up some if you don't then you could go wider. I only run about .025 but I also run much higher boost. You may even get buy with only one step colder with the low boost numbers. If you have a MSD and a hotter coil you may also get by with a wider gap it is all T&E.
uedlose is offline
Old 03-28-2013, 07:31 PM
chrstphrfenton
Yea I was wanting to swap to autolite 3923 or 3924 just wondering which was best I will prob go one step colder and see how they do.
I have (MSD) street fire box and coil so not sure on gap I will try .30 or .35 and see.
Thanks for the info.
Old 03-28-2013, 07:40 PM
adrnlnjnky700
adrnlnjnky700's Avatar
im running 3923 at .035 with the same supercharger.
adrnlnjnky700 is offline
Old 03-29-2013, 10:35 PM
deathsled
deathsled's Avatar
I use Bosch platinum +4. No gapping needed and Saleen runs great.
deathsled is offline
Old 03-29-2013, 11:40 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
that's fine, however the OP is running boost, what uedlose stated is exactly what the OP needs to do.
mjr46 is offline
Old 03-30-2013, 12:05 PM
chrstphrfenton
Thanks for the input the car has Champion RC9YC plugs in it now I noticed it is same heat range as 3923's but now another question the champions are non resistor but I drive on the street in traffic mostly so resistor type or non-resistor type?
Sorry just got this car in febuary and never had F/I car so just trying to learn a few things.
Old 03-30-2013, 12:08 PM
chrstphrfenton
I will be taking it to the track this summer and it's not tuned so it runs rich.
Mobiusone stang
09-07-2015 08:46 PM
Emblazoned
09-03-2015 10:45 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: What spark plugs and what gap should I run
