HeadLight/Fog lights Problem
Old 03-30-2013, 11:39 PM
5.0StangNewbie
5.0StangNewbie's Avatar
Post HeadLight/Fog lights Problem
Hey guys im Dan,
Recently bought my 89 GT Hatchback which came with a set of smoked aftermarket head lights and fog lights..I installed both my self and they were just regular bolt on and plug and play..no need to splice or change wiring of any sort.
That night i noticed that when i had both the Headlights and the Fog lights on at the same time that after a little while the lights would turn on and off (flickering, kind of)..but when i turned off the fog lights it would stop and it would be normal.
My question to you guys is, Do I need to change a fuse/relay or add something to give them more power( ex. resistor like HID's)? Or is this normal with aftermarket parts? The Bulbs are just the regular ones, not and HID's or anything.
I would like to drive at night with both on, but if that's not possible please let me know.
Thank You soo much for your time. Hope you have a great Day/Night.
Dan Q.
5.0StangNewbie is offline
Old 03-31-2013, 07:26 AM
BabyGT
BabyGT's Avatar
That should not be happening, as to how to fix it I don't know.
BabyGT is offline
Old 03-31-2013, 08:26 AM
eb2gt
eb2gt's Avatar
do a search on here. There is a solution fix for this problem and it is in the fog lights.
eb2gt is offline
Old 03-31-2013, 09:24 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
there is a tsb on rewire of fog lights using a relay, back in the day the oem wiring went through the switch, to juch current draw through the switch melted wiring, fuse box issues and so forth
mjr46 is offline
Old 03-31-2013, 03:37 PM
mattdel
mattdel's Avatar
http://www.corral.net/tech/maintenance/foglights.html
mattdel is offline
Old 03-31-2013, 04:54 PM
5.0StangNewbie
Thank you all! Especially Mattdel.. Dude you are a life saver! I will definitely be following those steps to fix this little problem
Old 03-31-2013, 07:49 PM
Js88lx
Js88lx's Avatar
Yup., plus with that new rewiring with the relay you will be able to use your fogs with your corners without headlights on.
Js88lx is offline
Old 04-01-2013, 12:32 AM
Dj_Seph
Dj_Seph's Avatar
Reminds me that I should have done this when I had the switch out.-_-
Dj_Seph is offline
djbigskrilla
09-20-2022 01:04 AM
jjwinel78
08-17-2015 03:34 PM
1st 4 eyed fox
08-15-2015 02:16 AM
philster0306
08-10-2015 11:33 AM
Quick Reply: HeadLight/Fog lights Problem
