Alternator wiring question
Old 04-07-2013, 12:06 AM
brettleh
brettleh's Avatar
Default Alternator wiring question
Any idea where this charge wire would be going? I have electrical problems with the car and want to simplify the wiring to make it easier to work on, not to mention make the lights stop flickering with the rev.
The larger wire (charge wire)
goes into a wire harness that goes UNDER the battery (i think). Can this wire go DIRECTLY to the battery, or does it have to go thru a voltage regulator? I have been looking at wire diagrams for this and it looks like it can go right to the battery but im not sure.
Without further ado, here are the photos of what I am refering to:
brettleh is offline
Old 04-09-2013, 07:26 AM
petrock
petrock's Avatar
Its hard to say what that wire does or goes to. It looks like someone installed it for some reason. The crimp connector to join the red & black wires definitely isn’t factory.
I would trace the wire until you find where it terminates. It may go to some electrical component, fuse, relay or a combination of those. It looks a little thin to be the wire to charge the battery, but its hard to tell from the pictures.
Good luck...
petrock is offline
Old 04-09-2013, 04:54 PM
Maxwelhse
Maxwelhse's Avatar
The alternator looks funky to me too, but I don't know "older" Foxes well at all, but my 1G alternator on my '91 looked nothing like that.
Anyhow, with that said, if you have a Fox and have charging problems, your first stop should be a 3G alt swap. If that means a serpentine belt from V-belt swap too, I'm even more in favor of it!
Maxwelhse is offline
Tivo304
08-28-2023 12:19 PM
2007StangV6
01-28-2016 06:09 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Alternator wiring question
