Bearing Clearancing
Old 04-08-2013, 04:44 PM
Duncan_GT
Duncan_GT's Avatar
Default Bearing Clearancing
Anybody have any tricks for getting more clearance on the main bearings? I have polished the crank, align honed the mains, and am using undersized bearings. Still dont have enough clearance.
Duncan_GT is offline
Old 04-08-2013, 05:21 PM
Boss_Hotrod
Boss_Hotrod's Avatar
If you have the crank machined, block line honed and use the correct bearings you should have the correct clearance. You may have to have the crank ground down to the next bearing size.
Boss_Hotrod is offline
Old 04-08-2013, 06:39 PM
reldla1996
reldla1996's Avatar
What clearance are you looking for, and what do you have?
reldla1996 is offline
Old 04-08-2013, 08:08 PM
Duncan_GT
Duncan_GT's Avatar
I want .003", im at about .0018-.002"
Old 04-08-2013, 08:10 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Ask jim at fordstrokers, iirc when he encounters such an issue he may mix and match undersize/oversize bearings to achieve the correct clearance.....but don't quote me on that...ask him
mjr46 is offline
Old 04-08-2013, 10:27 PM
reldla1996
reldla1996's Avatar
I'd be good with .0018 to .002, but I prefer them a little tighter. To get more clearance requires either expanding the bores (re-honing), or shrinking the crank (re-polishing)....
Old 04-08-2013, 10:28 PM
Duncan_GT
Duncan_GT's Avatar
Yeah i had a thread on the corral going w him. He was saying that the hone was probably on the low side and the crank is still on the high side. Its only the 1 and 2 journals. I remeasured and theyre at .0022". Which is better, and probably ok for the streets, but i dont want to spin a bearing because of it. Im using both shells of the undersized bearings
Old 04-08-2013, 10:29 PM
Duncan_GT
Duncan_GT's Avatar
Its a 351, i need a lot more clearancing
Old 04-08-2013, 10:35 PM
tinman
tinman's Avatar
Scotchbrite is your friend.
Use it carefully with frequent checks of just where you really are for clearance.
Only use the finer grades.......
tinman is offline
Old 04-08-2013, 11:37 PM
Duncan_GT
Duncan_GT's Avatar
Thank you, i had this idea but was hesitant to use it. Should i do it on the crank journal or the bearing?
Quick Reply: Bearing Clearancing
