Bell housing/flywheel inspection cover missing
Old 04-15-2013, 03:27 PM
CW
CW's Avatar
Default Bell housing/flywheel inspection cover missing
I was under the 84 GT that I bought a couple weeks ago and noticed the inspection cover was not on. It looks like the whole tin plate that normally goes between the block and bell housing may be missing.
What affects can this have?
So far I haven't noticed any driveability, starting, or shifting issues.
Its a T5 car, engine has been redone but not sure if its original, also not sure if the trans is original. The trans is very clean as well and shifts very smooth. Clutch is firm.
CW is offline
Old 04-15-2013, 03:59 PM
dawson1112
dawson1112's Avatar
That shield is there for a couple reasons mainly to inspect the fly wheel , but also to keep dust and crap out of the flywheel. A lot of pple fail to put it back on after a trans or clutch swap... I doubt it will hurt anything to not have it there Ive had tons of cars that were missing that cover.
dawson1112 is offline
Old 04-15-2013, 04:07 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
there is no inspection cover on a manual trans car it should be a solid index plate from top to bottom...
rmodel65 is offline
Old 04-15-2013, 07:22 PM
CW
CW's Avatar
Ok, I wasnt sure if it was solid or two pieces but either way its not there. Haha!
Should I worry about replacing it right away or is it not needed that bad?
CW is offline
Old 04-15-2013, 07:52 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
It indexes the starter and is a spacer for engine/tranny...I'd get one in there
mjr46 is offline
Old 04-15-2013, 07:54 PM
CW
CW's Avatar
I thought it had something to do with the starter as well, although so far it all seems fine. No odd noises or grinding.
CW is offline
Old 04-16-2013, 07:17 PM
nitrous_bob
nitrous_bob's Avatar
????????? what could YOU be talking about ?
cuz i think hes talking about this
where the cable goes into the clutch fork....
nitrous_bob is offline
Old 04-16-2013, 08:28 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
that doesnt go between the block and trans..
the way he is describing it he is missing this
and this
but because he has a manual trans it should look like this instead one piece
rmodel65 is offline
Old 04-16-2013, 11:53 PM
CW
CW's Avatar
Yes rmodel65 has it. That's exactly what's missing.
Should I hunt one down ASAP?
CW is offline
Old 04-17-2013, 05:03 PM
nitrous_bob
i just re-read it....
i saw "inspection cover" and didnt go on. ive never heard the plate referred to as an inspection cover before, and the cable dust cover is always missing.
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
winner99
10-01-2015 01:06 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: Bell housing/flywheel inspection cover missing
