door window rivets and regulator rivets help
Old 04-17-2013, 04:16 AM
GTnotchback
GTnotchback's Avatar
Default door window rivets and regulator rivets help
I know they are all 1/4 inch rivets that i need to put my glass, regulator, and lock actuator back in my door but can anyone tell me wha length i need? I think 1/2 inch for the regulator and 3/4 inch for the window and lock actuator. 7 rivets total. Thanks
GTnotchback is offline
Old 04-17-2013, 06:42 AM
petrock
petrock's Avatar
I prefer to replace window rivets with nuts/bolts instead of new rivets. Add a little blue lock-tight to the threads, snug it down and you’ll be fine.
petrock is offline
Old 04-17-2013, 06:44 AM
GTnotchback
i still want to know the correct rivet sizes but "petrock" you have realy got my attention...what size bolts?
Old 04-17-2013, 06:53 AM
petrock
petrock's Avatar
I’m not sure what size it is. I’d have to take my wifey’s car door panel off to check. I’d just get a micrometer (available for less then $10 at most auto parts store) and measure the length of the existing rivets. Then drill them out and measure the inner diameter of the whole the rivet went into. Then get nuts/bolts to match (plus a little extra length for the nut).
Good luck...
petrock is offline
Old 04-17-2013, 10:48 PM
capri debris
capri debris's Avatar
X2. I used nuts and bolts for my regulators and glass.... stainless button head allen bolts for the door locks. Much "gooder" than rivets. lol.
capri debris is offline
Old 04-18-2013, 05:27 AM
GTnotchback
went with 1/4 by 1 inch bolts. The car smells the same as it did with rivets. thanks!
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
jerrytubes
10-23-2015 12:11 PM
09-25-2015 06:58 PM
Quick Reply: door window rivets and regulator rivets help
