help with roller rockers
Old 04-19-2013, 03:31 PM
Sniper Clown
Sniper Clown's Avatar
Default help with roller rockers
I wanted to get some opinions from you guys on rocker arms. I'm in the process of building my motor and on the heads now. I have a 306 with a tfs stage 1 cam, gt40p heads. I wanted to know which rockers should I go with 1.7 or 1.6. which ones would be better for my setup.
Sniper Clown is offline
Old 04-19-2013, 06:30 PM
Duncan_GT
Duncan_GT's Avatar
1.7 rocker arms will give you .530/.542" lift with that cam. I'd be concerned with PtV clearance. Cam duration is what gets most people. You'll also have to upgrade your springs
Duncan_GT is offline
Old 04-19-2013, 11:40 PM
tinman
tinman's Avatar
I think that you'd check your piston/valve clearance no matter what rockers you use.
Comp Cams makes some very good rocker arms.......
tinman is offline
Old 04-19-2013, 11:43 PM
Duncan_GT
Duncan_GT's Avatar
I was going to recommend Trickflow
Old 04-20-2013, 06:00 PM
nitrous_bob
nitrous_bob's Avatar
yup, trickflow advertises that cam with 1.6
i think 1.7 would be too close for comfort, it is for me anyways
nitrous_bob is offline
Old 04-20-2013, 08:42 PM
Duncan_GT
Duncan_GT's Avatar
I honestly dont know too many common applications for 1.7's
Old 04-20-2013, 09:43 PM
reldla1996
reldla1996's Avatar
I ran the 1.7's with the factory cam for a couple years, and then with the Crane Cobra Cam for many years (.529/.513 with the 1.7's, with TF heads). More recently, I ended up with 1.7's with a custom cam in my new engine, to get .613/.610 (with AFR heads).
reldla1996 is offline
Old 04-20-2013, 11:09 PM
Duncan_GT
Duncan_GT's Avatar
I stand corrected
Old 04-21-2013, 02:27 PM
Black90notch
Black90notch's Avatar
I'm running 1.6 on edelebrock alum heads, 306, bcam, trick flo intake... She screams
Black90notch is offline
Sixer4Life
10-12-2015 04:26 AM
69MustangCoupe393cid
10-03-2015 10:33 AM
uedlose
09-30-2015 08:01 AM
Sixer4Life
09-28-2015 07:05 AM
JDWalton
09-24-2015 08:47 PM
Quick Reply: help with roller rockers
