Anyone running NITROUS?
the TNT system is nice when they say 100hp shot they mean 100 hp. like a NOS system when you use a 100hp shot its like 80hp. its all in how much want to spend
the ZEX kit is sweet only takes a few minutes to hook up.hooks up to the tps and a 12v source.
I dont have a TPS.I should have said nitrous on a carbed setup because thats what im running.Im not trying to go buck wild on a kit just the basics since this wont be used everyday.Just when i absolutely need it.</P>
</P>
What all is involved with installing a nitrous kit on a carbed setup?</P>
NX is the way to go and if you need a deal on a system let me know..you can check out here stuff at
www.nitrousexpress.com<edited><editID>vfast</editID><editDate>37973.671724537</editDate></edited>
on the carb setups. they have a spacer that goes in between the carb and intake. you need a 12v source, fuel lines and the N02 hookup. different fuel pump. not too much to your standard kits. but when you do the foggers that a little different
Yeah thanks everyone i know how it works and everything but i was just wondering how you carbed guys liked it?Also if you had any problems with the installs?</P>
This is for anyone what exactly is your timing set at for the nitrous?Im adding the MSD 6AL over the winter and wanted to know if anyone is using this ignition and nitrous and if so how do you go about your ignition retard?Also with a carbed 331 which do you recommend?Im not planning on using it alot so i want a setup that does the least amount damage because as we all know even a properly setup nitrous kit shortens the engines lifespan.</P>
