Passenger power window problem
Old 05-07-2013, 09:17 PM
95 gt 5.0
95 gt 5.0's Avatar
Default Passenger power window problem
I recently bought a 95 gt, up until this morning the passenger window worked fine. When I went to put it down this evening all I heard was the motor running. If I push down the window it doesn't move, but if I use the switch and push it down it moves, same with going up. Ironically I'm having the same problem with the rear drivers side window, it's a convertible. Any help would be appreciated.
95 gt 5.0 is offline
Old 05-07-2013, 09:35 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
you need to replace these bushings
CRL 1989+ Ford Bushing Kit for Power Window Regulator Gear- Pack - Amazon.com CRL 1989+ Ford Bushing Kit for Power Window Regulator Gear- Pack - Amazon.com
you need one kit per window motor
rmodel65 is offline
Old 05-09-2013, 05:58 AM
fixitman
fixitman's Avatar
Here is what i have done for a repair,it will last longer than the car, use there 1/4 inch well nuts ,trim the tops off where they will fit, you will need three for each motor ..
fixitman is offline
Old 05-09-2013, 08:26 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
you can just use 3 10mm nuts but the motors are supposed to b able to shear in the event someone like a child sticks their arms in the window it will break the rollers and not their arm..
rmodel65 is offline
Old 05-10-2013, 05:06 PM
fixitman
fixitman's Avatar
This is Why you use well nuts they are Rubber,they willnot wear out ,and if the motor gets in a bind they have some give,i would never use nuts (metal) thats not a safe repair .. just my 2 cents
fixitman is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
JonnyBlazeGT
11-03-2015 01:10 AM
movielover40
08-27-2015 10:13 PM
inyadreems
08-21-2015 09:10 AM
Quick Reply: Passenger power window problem
