New Rack and Pinion, Need toe set Help
Old 06-02-2013, 03:57 PM
Mach1BBFun
Mach1BBFun's Avatar
Default New Rack and Pinion, Need toe set Help
So I put in a new rack and pinion this morning and set the thread count on the outers to where it was before and the toe is out ridiculously far, I know it's supposed to be between -.5 to .5 degrees, could anyone with a newer rack and proper alignment hop under their car and give me a thread count to get me close enough to make it to an alignment rack (40 miles away). Thanks in advance.
P.s. I know it won't be perfect, every car is different.
Mach1BBFun is offline
Old 06-02-2013, 04:37 PM
reldla1996
reldla1996's Avatar
Measure across the tires, in the front of the tire and in the back of the tire, as high as possible with the weight of the car on the ground, to the same row in the tire tread pattern. You want 1/16" toe in (the front of tire measurement should be less than the rear of tire measurement), so measure and adjust until you get there. You will have to move the car backwards and forwards a few car lengths after every adjustment to let everything settle before you measure it again. You'll get there after 3-4 adjustments. Measuring someone else's car is not going to be right for your car.
reldla1996 is offline
Old 06-02-2013, 05:16 PM
Mach1BBFun
Mach1BBFun's Avatar
Hence the P.S. what I was asking for was a thread count to get as close as possible because its way off, a good starting point so I can do the above w/o starting a mile off
Old 06-09-2013, 09:24 PM
Mach1BBFun
Mach1BBFun's Avatar
For any that want to know
Old 06-09-2013, 09:27 PM
Mach1BBFun
Mach1BBFun's Avatar
For anyone who stumbles upon this, set it close by guessing, -.6, Always make sure youre even on the threads on both sides.
baddog671
07-26-2016 01:20 PM
TCStangerv6
10-11-2015 05:57 PM
KingRando
10-02-2015 08:06 AM
winner99
09-30-2015 07:04 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: New Rack and Pinion, Need toe set Help
