Hot start woes....
Old 06-19-2013, 03:27 PM
keeno
keeno's Avatar
Default Hot start woes....
1987 Mustang GT...Ford Racing mass air conversion, 24 lb injectors..A9l computer...mild comp cam , headers, explorer intake...5 spd.
When motor is hot, it won't crank...spins fast, doesnt drag..just left a local repair shop for a week...they couldnt fix it. Replaced TFI twice..no luck.
They said it has fire at the plugs..plenty of fuel pressure..injector pulse..fuel at the injectors. I'm at a loss as to what this could be...anyone have any ideas?
keeno is offline
Old 06-19-2013, 10:36 PM
mattdel
mattdel's Avatar
PIP inside the distributor. Good chance they didn't test it while failing.
Also for future reference, the term 'crank' refers to the starter, not the engine firing.
mattdel is offline
Old 06-22-2013, 08:01 AM
keeno
keeno's Avatar
After researching replacing the PIP...looks like its easier to just buy a brand new distributor. $81 at Oreilleys.... comes with new TFI ($60) PIP ($20) and cap and rotor ($30). Electronic parts are $110 separately...
keeno is offline
Old 06-22-2013, 08:51 AM
dawson1112
dawson1112's Avatar
Its either electronic related , or lack of compression . If they have spark and fuel I would think it would try to at least pop off under compression. warped head or not torqued down correctly when they get hot can loose compression.
dawson1112 is offline
Old 06-22-2013, 09:32 AM
keeno
keeno's Avatar
It starts and runs fine when cold....just when you turn it off and then try cranking after its hot...it just spins without even trying to start. It will start back up after it has cooled for hours.
keeno is offline
Old 06-22-2013, 09:33 AM
keeno
keeno's Avatar
We have replaced the TFI with 3 different ones....and swapped the coil...still not fixed.
keeno is offline
Old 06-22-2013, 12:26 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
so replace the dang pip in the dizzy.....judas....not rocket science, 3 tfi's and you haven't been able to arrive at this conclusion??
mjr46 is offline
Old 06-23-2013, 09:03 AM
darkmach1
darkmach1's Avatar
Is this on a new starter?
darkmach1 is offline
Old 06-23-2013, 09:35 AM
keeno
keeno's Avatar
yes it has a new starter.
keeno is offline
Old 06-23-2013, 12:10 PM
darkmach1
darkmach1's Avatar
How about the starter relay, those can be a MFer!
Quick Reply: Hot start woes....
