Procomp ebay heads?
Old 06-22-2013, 08:59 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Originally Posted by duncan01
thanks fellas I called and canceled the order. I'll be ordering AFR 165's Monday morning. I like the fact there a 58cc combustion chamber and should up the compression to about 10:1. Plus Ive heard nothing but good things a bout them
very smart decsion
mjr46 is offline
Old 06-22-2013, 10:05 PM
tinman
tinman's Avatar
I think that if it were mine I'd go up just one size on the intake.
Reason for this is I can 'grow' the motor a little and get even more out of it.......
tinman is offline
Old 06-23-2013, 06:41 PM
wydopnthrtl
wydopnthrtl's Avatar
What do you guys think about the CNC Edelbrocks offered by fox lake?
http://www.foxlakeracing.com/mod2.php?id=17
wydopnthrtl is offline
Old 06-23-2013, 08:09 PM
duncan01
duncan01's Avatar
the only reason im goin with that size is the dyno results show the torque comin on sooner than with 165 even though the 185 makes more power. But this is only a street car and torque is everything for me. The 185 makes most its power around 5-6k rpm I personally don't like spinning my car that high. If im not mistaken I get to keep my ford racing 1.6 pedestal mount roller rockers with them too.
What type of power gains should I expect with having my typhoon upper and lower, bbk shorties, new 24lb injectors, and going from 10 degrees timing to 14degrees???
duncan01 is offline
Old 06-23-2013, 10:40 PM
tinman
tinman's Avatar
Fox Lake has done some nice work in the past, I have a set of Trick-Flow twisted that they did a program on.
From what I saw on that link, I'd have to be a little skeptical about 303cfm @.600 lift with only a 200cc port.
If you really are after a big flow number get Vic.Jr. heads and have them run a program on them.
Those start out at 215cc and go nearly 300cfm @.600 unported right out of the boxes.....
tinman is offline
Old 06-24-2013, 08:46 AM
duncan01
duncan01's Avatar
http://www.jegs.com/i/Ford-Racing/39...-X307/10002/-1
Any one have experience with these
duncan01 is offline
Old 06-24-2013, 12:50 PM
duncan01
duncan01's Avatar
Well I wound up ordering gt40x heads with 58cc combustion chambers and ordered some new ford racing lifters as well. Gonna start takin her down to short block this evening, parts will be here wednesday and should have it back together by wed nite thursday at the latest.
duncan01 is offline
Old 06-25-2013, 12:08 AM
tinman
tinman's Avatar
NEVER, EVER put a time line on how long something is going to take to install.
You need accuracy, not speed........
tinman is offline
Old 06-25-2013, 04:36 AM
duncan01
duncan01's Avatar
Hahaha thanks, if I was going for speed it would be up and running in a few hours not days. Broke everything down last night so now its just a waiting game. Shoot, the worst part is fighting with the header studs were they connect to the down tubes.
duncan01 is offline
Old 06-26-2013, 08:53 PM
darkmach1
darkmach1's Avatar
I know a couple guys with pro-comps on 347 motors, do they work? Yes, but there's way better out there. For best results on these heads the ports should be matched (ported) since there will most likely be different intake/exhaust flows for each cylinder and all of the valvetrain should be from another company, by this point you're better off going AFR or TF.
darkmach1 is offline
Quick Reply: Procomp ebay heads?
