Head gasket ???
Old 06-24-2013, 04:50 PM
Al Saggese
Al Saggese's Avatar
Default Head gasket ???
I have Edelbrock heads on my 93 LX i am using edelbrock head gaskets.On the gaskets it has front printed on one end.Now in order to keep the fire ring(The metal part of the gasket that go's around the cylinder)the same on both sides front would be in the back does this matter or not.One side of the gasket the ring is flat on the other its open in the center.
Attached Thumbnails Head gasket ???-104_2520.jpg   Head gasket ???-104_2521.jpg   Head gasket ???-104_2522.jpg
Al Saggese is offline
Old 06-24-2013, 08:02 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you don't worry about that. place the gasket on the block with the labeling "front" as indicated, one side will be facing down at the front labeled "front" any other way than this is wrong....meaning the way you intend to do it = wrong!!
mjr46 is offline
Old 06-25-2013, 12:01 AM
tinman
tinman's Avatar
^^^^^^^^^^^^^^^^^^^^^^^TRUE^^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^
tinman is offline
Old 06-25-2013, 01:33 AM
Al Saggese
Al Saggese's Avatar
Thanks for the info.
Old 06-25-2013, 11:23 AM
Duncan_GT
Duncan_GT's Avatar
If you do it the way you're talking, the water jacket holes in the gasket won't line up. You'll run into an overheating issue pretty quick
Duncan_GT is offline
GimpyHSHS
19
12-19-2023 01:12 PM
kevsgt
10-09-2015 10:12 PM
Dathan
10-05-2015 05:52 AM
Drastang
09-30-2015 03:48 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Head gasket ???
