lost
Old 07-10-2013, 08:39 PM
bowers1990
bowers1990's Avatar
Default lost
i have a stock 5.0 i just got gt40 upper an lower intake also have 24lb injectors and the right maf for them do i need anything eles???
bowers1990 is offline
Old 07-10-2013, 09:05 PM
bowers1990
bowers1990's Avatar
[QUOTE=bowers1990;8246101]i have a stock 5.0 i just got gt40 upper an lower intake also have 24lb injectors and the right maf for them do i need anything eles to run the 24lb injector??
Old 07-10-2013, 09:26 PM
88 orangepeel notch
88 orangepeel notch's Avatar
Nope, plug and play. Computer might take a few miles to learn upgrades after reset.
88 orangepeel notch is offline
Old 07-10-2013, 09:29 PM
dawson1112
dawson1112's Avatar
It sounds like your all set . The 24s will work fine as long as you have the maf calibrated for the. You may want to get some vacuum line and some caps to plug some of the vacuum ports on the gt40 intake if it came from an explorer there are a few ports you wont use. And you may need to run some longer vacuum lines, I did on my 94 but on the 91 set up maybe not. Tube of black or copper rtv sealent for the lower intake . And if you don't have studs in place for the lower I would get at least 4, 2 on each side because they help to guid the lower intake into place. Not to mention they hold the lower gaskets inplace while you lower the intake down .
dawson1112 is offline
Old 07-10-2013, 09:49 PM
bowers1990
bowers1990's Avatar
okay cool? either of you guys ever heard of havin to change the cam??
Old 07-10-2013, 09:57 PM
Duncan_GT
Duncan_GT's Avatar
Changing the stock cam? That's ludacris. The stock HO cam is a beast
Duncan_GT is offline
Old 07-10-2013, 10:03 PM
dawson1112
dawson1112's Avatar
Not unless its broken lol ... Or your gonna do the triple heads cam intake combo.
If you ever get around to the heads that is a perfect time to upgrade the cam. Just because almost every thing you need to take off is off , and if you have to match lifters , springs , push rods for the cam you may as well match them to an upgraded cam
Old 07-10-2013, 10:05 PM
bowers1990
bowers1990's Avatar
okay i wasnt goin to but a buddy said he thought i had to but wasnt 100%... who eles is runnin 24lbs can you tell a differance???
Old 07-10-2013, 10:36 PM
dawson1112
dawson1112's Avatar
I am not , but I doubt you will see any gains with that set up, your restrictions are the heads at the moment., You don't need the 24s at all right now , but they wont hinder any thing. These cars are like Ice cream ... Its good by it self, but its better with chocolate , peanuts and a cherry on top. lol each uprade compliments the next.
Old 07-11-2013, 07:44 AM
bowers1990
bowers1990's Avatar
What about stock open chamber 351 heads I have them layin around
Quick Reply: lost
