Aftermarket Alarm
Aftermarket Alarm
There is an aftermarket alarm in my 95 GT. Goes off continually since I had to get a new key fob and program it to work with the car. There's a g switch mounted under the steering column, a red diode enable/disable switch mounted on the top of the steering column. Some kind of override switch down near the hood release. And a horn in the engine compartment. I can't find anything else. I have to use the override switch all the time to start the car. I've disconnected the horn, but the alarm drains the battery. Any ideas on what to do, where I can maybe find the alarm?
Its probly wired into the door locks ignition and parking/headlights. If professionally installed you may have to remove the drivers side knee panel under the steering column to get to it.
Most professional installers would make it somewhat difficult to get to the box .
Dan04COBRA
09-30-2015 11:46 AM
09-24-2015 09:18 PM
