dizzy gear stripped off...cause?
Old 07-22-2013, 07:24 PM
2011scgt
2011scgt's Avatar
why not take a drill and spin the rod on the pump see how it does
2011scgt is offline
Old 07-22-2013, 07:41 PM
Goosepoop302
Goosepoop302's Avatar
sounds like a good idea, although I have never done this before... If you can explain in more detail.. I don't wana mess anything up worse
Goosepoop302 is offline
Old 07-22-2013, 09:03 PM
Duncan_GT
Duncan_GT's Avatar
Take the dizzy out. The oil pump shaft inserts into the bottom of the distributor (the crank drives the cam via timing chain, the cam drives the dizzy via the cam gear/dizzy gear, and the dizzy drives the oil pump). It'll be below the cam gear, you'll see it. TAPE some extensions + socket together, attach an electric drill, and spin the pump
Look at the bottom shaft of the dizzy. There will be a hexagonal insert = oil pump shaft
Duncan_GT is offline
Old 07-24-2013, 06:16 PM
Goosepoop302
Ok, I have seen that shaft and believed that was the process.... Will I be able to feel a bind with a drill or am I looking/feeling for something else?
Old 07-24-2013, 06:47 PM
Duncan_GT
Duncan_GT's Avatar
Spin it, it will be a lot easier to see with a valve cover off. It should start to cover everything pretty adequately in oil. If not, well there's your culprit
Old 07-27-2013, 08:01 PM
Goosepoop302
well some interesting discoveries were made! after pulling the engine and putting it on a stand I removed the oil pan. upon removing it I found some interesting things inside! (see pic)
one appears to be my oil pump shaft...also answers why I couldn't figure out how to spin the damn thing!
the other I believe is from some lifters I had blow apart quite some time ago.. They are shaped the same and appear to be the same size wire material...
you can see a small piece of wire stuck in the oil pump (the cause)
so time to get a new pump.. is there anything else I need to inspect to make sure no damage was done to the cam or pistons? I will pull the heads if I absolutely have too...may use that as an opportunity to paint some engine parts
Attached Thumbnails dizzy gear stripped off...cause?-img_20130727_195042.jpg   dizzy gear stripped off...cause?-img_20130727_195109.jpg   dizzy gear stripped off...cause?-img_20130727_161617.jpg
Old 07-27-2013, 08:27 PM
Goosepoop302
also pulled these from the oil pan area.
Attached Thumbnails dizzy gear stripped off...cause?-img_20130727_202312.jpg   dizzy gear stripped off...cause?-img_20130727_202307.jpg
Old 07-27-2013, 09:43 PM
tinman
tinman's Avatar
You're going to need an oil pump, a new drive shaft for it, (I'd use an ARP), plos I'd get a good distributor, like an MSD.
I have a hard time thinking that gear just fell off the old one, everyone of them I've ever had to work with was at light press fit.....
tinman is offline
Old 07-27-2013, 11:17 PM
Goosepoop302
the gear didn't fall off, it was still on the shaft when I pulled the dizzy... I removed it myself. I Feel no play in I currently but agree I need a new one. Is msd really the best option? oil pump shouldn't be an issue, I just want an oem replacement.
Old 07-28-2013, 09:33 AM
Duncan_GT
Duncan_GT's Avatar
Just get a standard melling replacement. Run ya like $30
Quick Reply: dizzy gear stripped off...cause?
