How to test the voltage regulator - squirt PCB
I have my dash cluster out and would like to test the Voltage Regulator or squirt module located in the upper RH corner of the cluster on the rear. It
slides out when the latch is released.
I am having gas gauge problems with it always being above Full and this has been mentioned as a possible source of the problem - but changing parts without testing them is a waste of money...
But taking out the dash cluster again for not testing the module is not a good thing....
Anyone know how to test it?
Your problem is likely a short to ground in the wiring some where between the sending unit and the gauge.
The float mechanism operates a potentiometer (variable resistor) empty the float is at its lowest this creates a 0 ohm reading or very low resistance the gauge registers this just like an ohm meter would measure ohms open or no resistance = empty. When the tank is full the float is at its highest creating a high resistance.
If your gauge reads way above the full mark this means that there very high or infinite resistance causing the gauge to peg above the full line. A short to ground in the + wire that goes to the sending unit for the gauge will cause infinite resistance .
Removing power by disconnecting the battery will test this. With the battery disconnected the gauge should drop below empty.
Thanks, will observe the gauge when I put the cluster back in
I have the cluster out now for cleaning, bulbs and a new plastic cover..will check it when I re-install.
Since I was in there now, checking the thing seemed like a good idea...no
matter the problem - a gas gauge is necessary...using the odometer is just
WAG at times....
WAG at times....
Measuring ohms on a circuit/component can only be (reliably) done when there is no current/power/amps flowing through it. If there is any current flowing the ohm reading will be way off and could potentially damage your meter. An ohm meter works by sending a fixed amount of volts & amps down one meter lead, through the circuit, and read the amount of volts & amps that appears at the other meter lead. It then applies the equation for Ohms Law (resistance = volts / amps) to determine the amount of resistance in the circuit.
This is also why doing an ohm measurement to determine the health of a circuit is virtually useless, unless you already know what the ohm reading should be ahead of time. To properly check the health/condition of a circuit, you need to have current flowing through it. So it has to be plugged in and turned on. Then use a voltage drop test. If the voltage across the circuit/component drops more then .5 volts, then you know there is a problem with the circuit. If it is below .5 volts, then the circuit is fine. Its that simple.
That just tests that the gauge is able to read the current flowing through the circuit. It doesn’t test the fuel tank sending unit or any of the other circuitry involved.
Thanks for all the info
The fuel gauge does move to about 3/4 when the key is off.
When On it moves over Full and stays there...will start checking at the tank and go forward on the wires when the car is back together again. If
needed, will drop the tank and check/change the fuel sender. It will work properly soon...
Will have the new dash parts - dimmer switch and new gauge cluster plastic cover in a couple of days. Then I should have lights in the dash again.
I think I found the problem on the blinking Air Bag light, car was in a front end accident and PO fixed the problem after being paid for the insurance value
and then bought the car back as Salvage. He did the fix "on the cheap" and did not replace the harness and air bag sensors near the headlights...hence
the Air Bag warning light! Will just take out the Air Bag bulb and live with the "beeping" or disconnect the aural warning device...
Am concerned that replacing that harness (cheap to buy) might not fix the problem(s) and might set off the air bag or cause more ... will live without
until the more important problems are resolved.
Need to find a solution on how to replace the vertical rubber seals on the quarter windows, have the new seals but NO ONE KNOWS or is TELLING how to change them...I cannot see how the two metal pieces are attached.
Have dash lights now
With the new dimmer switch, I have now have dash lights and the headlight switch etc is illuminated!
The new plastic gauge cover really makes a difference!
Took out the Air Bag bulb and will remove the connection of the "beeping box" so I not hear the aural warning all the time..
Still have to put the lower stuff back on but that is for another days work. Gas gauge still reads over Full so I will start chasing down that problem while the dash parts are still off the car, just in case...
jwog666
12-27-2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
GT350 S550 Tech
09-29-2015 03:29 PM
