Moisture/wetness between intake manifolds?
While disassembling the top end of my engine I noticed some moisture on the gaskets between the upper and lower intake manifold. I have a spacer and gaskets between them currently.. the moisture appeared closer the the center holes, when I installed I try to tighten from the middle out. Is the a sealer (rtv?) or different gasket that would work better or with what I currently have?
Did you wash your engine down recently? I cant see any way moisture would get there unless you sprayed the engine down and it seeped down along the long upper intake bolts.
Maybe a little rtv on the heads of the bolts before torque em down.
Doesn't seem like coolant, could be oil but seems thin for that.. I'll take a pic of gaskets so you can see the general area of it
daltron
04-28-2016 08:10 PM
