Oil Pump Driveshaft
Old 08-09-2013, 10:48 PM
Duncan_GT
Duncan_GT's Avatar
Default Oil Pump Driveshaft
Do you guys normally keep the toothed washer on the oil pump drive shaft installed? It's late and I'm retarded, and I installed the oil pump + pickup + pan and turned around to look at the drive shaft. It's an ARP unit. I was going to drop it down the distributor hole, but the washer catches before it reaches the drive hex on the pump.
So........ do I need to drop das pan?
Duncan_GT is offline
Old 08-09-2013, 10:52 PM
dawson1112
dawson1112's Avatar
You have to pull the pan and pump then put the oil pump shaft through the bottom witht the end with the washer on the dizzy end. That washer is there to keep the shaft from lifting out when you pull the dizzy.
dawson1112 is offline
Old 08-09-2013, 10:58 PM
15austin
15austin's Avatar
It doesent 'have' to be in there. All it does is keep it from comming out when u pull out the dizzy.
15austin is offline
Old 08-09-2013, 11:01 PM
dawson1112
dawson1112's Avatar
Make sure you test fit the dizzy on the block and make sure the shaft is not pushing down to hard onto the pump. It is best if you put the dizzy on then flip the engine over slide the shaft into the block till it is fully in the dizzy. button it all up.
Old 08-09-2013, 11:04 PM
Duncan_GT
Duncan_GT's Avatar
Originally Posted by 15austin
All it does is keep it from coming out when u pull out the dizzy.
Oh, duh. Told you it was late.
Welp, guess I'm off to pull the pan!
Old 08-09-2013, 11:22 PM
dawson1112
dawson1112's Avatar
Yea your right it doesn't need to be there , I just like to have it there because is supposed to be there lol . Im kinda OCD like that.
Old 08-10-2013, 12:28 AM
Duncan_GT
Duncan_GT's Avatar
I'm the same way. I couldn't turn the block over on the stand due to having the heads and intake installed = heavier than sh*t. Lol. Plus my oil pan studs and trying to keep the gasket in place while I hold the pan with one hand and wrench in the other made for an interesting time.
BUT, it's done. Hopefully no more stupid mistakes for awhile. Hopefully. Lol
Old 08-10-2013, 12:33 AM
dawson1112
dawson1112's Avatar
lol awww hell you got the heads on already ? your getting close now.. Get some pics of that beast up man.
Old 08-10-2013, 08:09 AM
Duncan_GT
Duncan_GT's Avatar
Yeah while my buddy was welding up the oil pump pickup, i converted an old hydraulic lifter to a solid and checked pushrod length and ptv clearance
Old 08-10-2013, 10:24 PM
tinman
tinman's Avatar
Thought that I was the only who could this type of screw-up........
tinman is offline
mtgldr
02-03-2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
9550
10-26-2015 05:01 PM
b8checker
09-30-2015 07:11 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Oil Pump Driveshaft
