Lifter tap? motor knocking? bad header gasket?
Old 08-10-2013, 05:42 AM
IvanFiveLiter
IvanFiveLiter's Avatar
Default Lifter tap? motor knocking? bad header gasket?
just a few weeks ago I started hearing this sound from my engine bay. I have heard that it could be a lifter tap or exhaust leak because of a bad header gasket but I doubt its an exhaust leak. The right side of the motor (when standing infront of the bay) has a clicking sound on a cold start but seems to get quieter when the car warms up. Car drives fine still has power nothing different but has a ticking sound. A few short videos below-
IvanFiveLiter is offline
Old 08-10-2013, 06:09 AM
dawson1112
dawson1112's Avatar
Sounds like lifter tapping to me. If it goes away after a min our 2 of running it is probly a lifter taking a bit longer to pump up.
If your oil pressure is good, you can start changing the oil often. It could be a bit of carbon or something in there. Sometimes frequent oil changes will help clean things up a bit if there is a lot of oil carbon build up. Maybe some seafoam in the oil or marvel mystery oil lol .
Or pull it apart and start checking parts. I wouldn't drive it too hard while that sound is present.
dawson1112 is offline
Old 08-10-2013, 08:44 AM
IvanFiveLiter
My oil pressure gauge reads about 60-80 on a cold start after driving the car drops down to about anywhere from 20-40 it varies. I don't drive the car too often it depends and not such far distances or hourly trips. Oil was changed with royal purple when it was tuned back in April. Id hope that an oil change could fix that. I would pull it apart but I don't have those skills yet. Any idea what it would cost with parts and labor to fix the problem if needed too? I know different places have different labor rates, ill be going to a mustang shop I go too if needed
Old 08-10-2013, 08:46 AM
IvanFiveLiter
compared to how some people treat their mustangs, I seem like baby. I have owned the car for 3 years and the clutch has been dumped about 5 times total! 3 burnouts, only way I ever really drive the car hard is doing anywhere from 1st to 2nd gear rolls. Dumping it otherwise on these tires is useless haha
Old 08-10-2013, 10:11 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
pull the valve cover on that side and make sure there are no loose rockers
mjr46 is offline
Old 08-14-2013, 03:12 AM
IvanFiveLiter
went to a mustang shop they checked it out and everything was ok. I was glad to see the girl wasn't on the verge of getting sick!
Old 08-14-2013, 06:15 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Glad to hear, so what was the tick?
88 orangepeel notch is offline
Old 08-15-2013, 12:15 PM
IvanFiveLiter
Honestly im not sure, when that sound occurred the car was not started for over a week. I was waiting for a little while before seeing the mechanics and showed the owner the video he said it could be a broken pushrod. But i remember the sound had stopped when they checked it out. Oil pressure was good and the mehanic reccomended a oil change for some peace of mind. The car had a full synthetic oil change in april and i probably havent even pit 1000 miles in it if that since. I just hope it doesnt come back.
Old 08-15-2013, 02:18 PM
Duncan_GT
Duncan_GT's Avatar
Only other thing I could think of is an exhaust leak
Duncan_GT is offline
Old 08-15-2013, 09:46 PM
tinman
tinman's Avatar
Sure sounds like a rocker arm problem to me.
I'd check both sides, all 16 of them...........
tinman is offline
Granatelli Sales
01-20-2020 12:34 AM
musnicki
09-23-2015 07:11 AM
cbird1177711
09-02-2015 04:12 PM
teeeeg67
09-01-2015 11:53 PM
Quick Reply: Lifter tap? motor knocking? bad header gasket?
