Dead...Dead...Dead
Dead...Dead...Dead
Hope someone here can guide me in the right direction.
I had the front clip changed out on this car....It ran when I took it to the frame shop....now....no go.
When you connect the battery cables...the fuel pump starts running, (key off...out of ignition), and the idiot light on the dash comes on, and stays on.
Pressure to the fuel rails.....no spark...no start...ideas / CCRM relay(s) stuck, bad?
Frame shop just scratching their heads, and no help.
Sounds like they pinched a wire somewhere. Or cut through a wire that's now grounding on the frame somewhere. I'd hazard a guess its somewhere in the ignition wiring, since the pump and dash lights come on. Double check around every where they touched on the car. Circle around anywhere something was replaced on the car and look for cut/frayed/pinched/smashed wires.
