Head bolts
Old 08-24-2013, 07:38 PM
dawson1112
dawson1112's Avatar
Also op I see that the alternative oem part number is for the ford head bolts and those are TTY and need replaced after use. So I would not reuse those bolts.
dawson1112 is offline
Old 08-25-2013, 09:20 AM
Duncan_GT
Duncan_GT's Avatar
Originally Posted by dawson1112
Yea I know but that bolt with the stud on it would be one of the out side short head bolts and the stud could be used to fasten something else on it.
Oh yeah. Duh
Duncan_GT is offline
Old 08-25-2013, 01:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the one with the stud went on passanger side and iirc the fuel lines had a bracket that fastened to it
mjr46 is offline
Old 08-25-2013, 02:55 PM
mongolchuck
mongolchuck's Avatar
Thanks for all the input. I just used all the bolts and not either of the studs. And yes they are TTY and new.
mongolchuck is offline
Old 08-25-2013, 03:40 PM
Duncan_GT
Duncan_GT's Avatar
Did the kit come with extra bolts?
Old 08-25-2013, 04:07 PM
dawson1112
dawson1112's Avatar
I seen a diagram of the engine bolts and the ones with studs were used in the exhaust manifold and were used to hold a heat shield on.
Since this bolt set is oem ford part replacement the option to have a heat shield on some engines existed so they included those bolts just in case you need them .
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: Head bolts
