Car will start W/out key in Ignition.
Old 08-27-2013, 05:59 PM
msd143
msd143's Avatar
Exclamation Car will start W/out key in Ignition.
So I found out today that I can turn the ignition and start the car without the key being in. The key and ignition will stick in the start position as well. If I just replace the ignition cylinder will this fix the problem or will there be more internal problems in the steering colum?
msd143 is offline
Old 08-27-2013, 06:14 PM
dawson1112
dawson1112's Avatar
Sounds like the ignition switch it self is bad , located behind the lower steering wheel shroud on the column
dawson1112 is offline
Old 08-27-2013, 07:06 PM
msd143
msd143's Avatar
Do the mustangs have the small access hole in the bottom of the colmn to push the button in to release the lock cylinder? If so there shold be no reason to tear the column apart, just replace the cylinder.
msd143 is offline
Old 08-27-2013, 07:12 PM
dawson1112
dawson1112's Avatar
The cylinder is not your problem , It is more likely the switch that the cylinder activates.
Old 08-27-2013, 07:21 PM
msd143
msd143's Avatar
In my thinking, if the cylinder was good and working, then it should not allow anything to turn without the key in the cylinder.
msd143 is offline
Old 08-27-2013, 08:03 PM
dawson1112
dawson1112's Avatar
That cylinder is nothing more than a lock, It rotates and pushes a linkage rod that moves a switch in the column . That switch in the column is where the power is supplied to the ignition.
Old 08-27-2013, 09:03 PM
fullmonte60
fullmonte60's Avatar
I had a problem that the cylinder wouldn't always come back after start-up unless I forced it. the engine was running but I had no light, accessories, etc. I changed the cylinder last w/e and it's been good since. but i'm thinking 89 setup is way different. with a t20 bit, a Phillips head, a new cylinder and 5 mins you can steal these cars...lol
fullmonte60 is offline
Old 08-28-2013, 06:49 AM
BabyGT
BabyGT's Avatar
His problem is the lock will turn without the key, doesn't sound like anything is wrong with the actual switch to me, says car starts without key, then the "lock" gets stuck on. I'd replace the cylinder first as its cheaper then go from there.
Yes there is an access hole to remove the cylinder when turned to the correct position.
BabyGT is offline
Old 08-28-2013, 07:39 AM
dawson1112
dawson1112's Avatar
Lol yea I had a serious brain fade on this one lol for some reason I was relating this to a previous post I seen where the car would crank it self when the battery was connected , and it would start with the key off. lol
Old 08-28-2013, 09:38 AM
BabyGT
BabyGT's Avatar
Yeah I commented on that one. He should just take it back to the shop.
BabyGT is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
drumhedd2005
08-13-2015 09:59 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
89blueslug
08-10-2015 07:20 AM
Quick Reply: Car will start W/out key in Ignition.
