Few questions - Page 2 - MustangForums.com
Old 09-15-2013, 08:33 PM   #11
Wayne220
problem fixed, alternator wiring was problem.
Wayne220 is offline   Reply With Quote
Old 09-15-2013, 09:45 PM   #12
tinman
Car in the video has a sticking lifter.
I also think that the carb floats are not set right.
If your car gas the same symptoms it may well have the same problems.....
I maybe the last of the carb guys on this board....
tinman is offline   Reply With Quote
Old 09-15-2013, 11:30 PM   #13
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Quote:
Originally Posted by tinman View Post
C
not quite...I'm still here
mjr46 is offline   Reply With Quote
Old 09-17-2013, 07:36 AM   #14
Wayne220
It as not been doing like the car in the video since alternator wire was correctly hooked up. I do know the carb needs rebuilt as the idle is random when you push clutch in (goes up to around 2k until you tap throttle).
Old 09-18-2013, 05:36 PM   #15
Wayne220
maybe someone can help with this:
My 85 does not have a pointer like that(the 1 and 2). IT only as the circle one #3 in image? Do i set my timing on the #3 for it?
... hope that makes sense, after 10 hour work day I'm... tired.
Old 09-18-2013, 06:59 PM   #16
uedlose
uedlose's Avatar
carb like said could need the floats adj. what is the fuel pressure at if it is to high it can drip also. You could also change out the needle and seat it will also make it drip.
Clutch adj. grab the clutch pedal and pull it to you it is a self adj. setup up if it is stock I think they were like that in 85 also I had one years ago and really cant remember.
Dont know about the tap if I cant hear it.
Sounds like the pointer is broke off or someone has changed it out. the hole from what I was told was for a scope back in the day.
uedlose is offline   Reply With Quote
Old 09-19-2013, 07:25 PM   #17
Wayne220
It looks factory, does not look like anything was broke off it. Guess i could buy a different one for it.
Intake manifold replacement Dokilar 4.6L (1996-2004 Modular) Mustang 15 10-16-2015 08:13 PM
Win $1500 Worth of RTR Parts - AmericanMuscle AMAlexLazarus AmericanMuscle.com 3 10-02-2015 08:06 AM
October Sale - AmericanMuscle AMAlexLazarus AmericanMuscle.com 0 10-01-2015 10:29 AM
Hot Lap: 2015 Roush RS3 Test + Build a Supercharger! - AmericanMuscle.com AMAlexLazarus AmericanMuscle.com 0 10-01-2015 09:21 AM
Hello, new user with an older Mustang and a question treesloth New Member Area 4 09-28-2015 07:03 AM
