Temp gauge doesn't work anybody know how to fix it?
Old 11-07-2013, 09:05 PM
mustangfan305
mustangfan305's Avatar
Default Temp gauge doesn't work anybody know how to fix it?
hey guys i have a 1988 foxbody lx 5.0 hatchback i recently just did a radiator flush and changed out the hoses on the radiator (Upper, and lower radiator hoses). i noticed that my temperature gauge doesn't read anything i just stays down like if the car was off. but all my other gauges work like oil pressure, fuel gauge etc.... ive noticed that a lot of fox bodies have problems with there gauges stopping working. my question is does anybody know how to fix the gauge or replace it i don't want to buy any aftermarket gauges i want to keep it looking stock and clean in the inside.
mustangfan305 is offline
Old 11-08-2013, 03:42 AM
dawson1112
dawson1112's Avatar
Was the gauge working before you drained the coolant and flushed everything? If so it is likely that you have an air pocket in the lower intake. Sometimes it helps to raise the passenger side of the car on a jack as high as you can or park on a steep hill. Let the car idle with the cap off the radiator till the thermostat opens and sometimes squeezing the top hose will help get the air out.
Its also possible that the temp sender on the drivers side of the intake is bad or the wire is off of it. It should be a single wire going to it.
If the gauge it self is bad you can change just gauge in the dash cluster but you have to remove the cluster and disassemble it. The temp gauge and battery voltage are a single unit.
I would firs check the other stuff I mentioned before tearing the dash apart
dawson1112 is offline
Old 11-08-2013, 03:56 PM
mustangfan305
thanks for the help i am definitely going to try that when i get the chance too.
Old 11-08-2013, 08:47 PM
Bubba 95SN
Bubba 95SN's Avatar
Ground the temperature sending unit wire. Turn key to on. Does gauge go upto H? Turn key off before it pegs gauge. Does this, replace sending unit.
Bubba 95SN is offline
djbigskrilla
09-20-2022 01:04 AM
Spiral534
10-06-2015 04:31 PM
MXBT187
08-20-2015 02:36 AM
jjwinel78
08-17-2015 03:34 PM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: Temp gauge doesn't work anybody know how to fix it?
