pressure issues
Old 11-20-2013, 11:18 AM
dawson1112
dawson1112's Avatar
150 is far to cold for the engine to run to its full potential. The ecm wont even go into closed loop until around 180. Also at 150 its not hot enough to effectively burn oil vapor off your gonna end up with a lot of cabon deposits on the valves and pistions and likely foul out your plugs.
What does the pillar gauge read with the thermostat?
dawson1112 is offline
Old 11-20-2013, 11:22 AM
SLADE1988
SLADE1988's Avatar
don't know haven't put it in yet ill do that and get back to u
SLADE1988 is offline
Old 11-20-2013, 12:00 PM
SLADE1988
SLADE1988's Avatar
what is optimum running temp?
Old 11-20-2013, 12:36 PM
dawson1112
dawson1112's Avatar
195-215 is right about where mine always hovered at.
Old 11-20-2013, 02:38 PM
SLADE1988
SLADE1988's Avatar
new thermostat and gasket..... temp stays at 190 at idle.... can get it to about 195 at about 2 grand..... will my car run better now that the engine is warming to spec
Old 11-20-2013, 02:58 PM
dawson1112
dawson1112's Avatar
It will at least go into closed loop now and not run so rich. The computer will have a much better handle on keeping timing and air/fuel mix optimal.
LOL see you were worrying about nothing.....
That's pretty good temps for texas, you may see it climb to 215 or 220 with some heavy footed driving . The fan doesn't even come on until 210 iirc.
Old 11-20-2013, 03:18 PM
SLADE1988
SLADE1988's Avatar
I ran my fan to an ignition relay because it wasn't coming on at all so now its just on lol...... but ya like I said at first I only paid 800 bux for the car.... score!!
Old 11-20-2013, 03:25 PM
SLADE1988
SLADE1988's Avatar
and also will I get better gas mileage?
Old 11-20-2013, 03:58 PM
dawson1112
dawson1112's Avatar
For sure if the car never went into closed loop then it was always dumping extra fuel.
Same way a carbed car with a stuck choke uses more fuel.
Old 11-20-2013, 04:07 PM
SLADE1988
SLADE1988's Avatar
nice ..... ready to get off work so I can test it out
Quick Reply: pressure issues
