Mass Air Conversion
Mass Air Conversion
I know I'm probably one of the last to convert to mass air .Also I know there is A speed density sit but it doesn't get a lot of looks like this area does.
So I'm wanting to convert to mass air .I've found this kit on eBay from fiveology racing. Ha anyone tried their kit and will I need a different wiring harness or can I use the speed density one? Thanks for any in put.
STAGE 2: designed for stock to mildly modified engines with airflow requirements up to 700cfm. Fuel injector calibration sizes include 19lb, 24lb and 30lb. A reference chart is provided below to assist in determining fuel injector requirements based on application type.
•OEM EEC-IV Processor
•NEW 73mm MAF Housing
•OEM MAF Sensor
•NEW Wiring Harness
•NEW Short-Ram Air Intake
•NEW Mount Bracket
•NEW Instructional Sheet
•OEM MAF Sensor
•NEW Wiring Harness
•NEW Mount Bracket
If you could post a link to the ad, that would help. Does the ad say it comes with a new harness? I think you'll need a MA harness. Someone correct me if I'm wrong.
I've used the mass air ad on wire harness for my conversion. Bought the harness it came in a ziplock bag, mass air sensor and computer from Autozone, cold air intake off ebay.. ran great from the first time I started it up. 11 years ago
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
