do i need new valve springs? and seal question
#22
your spring area is stock and not modified. but i was so caught up in your springs i forgot to mention. you can not run any type of perf cam with these heads because your compression is too low. you need around 9.5:1. if your heads ate not p's you need to mill .025" off from stock and run thinner head gaskets. do it now that they are off, you will thank me later. am i gonna need some more beer for this round, i'm ready, lol.
#23
new springs are ordered comp cam 986-16 as recommended by comp cam. of course they want you to use their springs. whatever. i think i realize i dont actually have to use their springs, but in an effort to make everything easier and faster, i bought them.
to use these springs with my gt40 heads, theres some head machining required. theres a step around the stem base where the springs sit that will apparently need to be machined flat, and maybe the stem guide OD may need to be cut thinner, and different stem seals need to be gotten. i already bought replacements seal for what i had, may be no good and have to be returned. returning them isnt a huge deal, but its just a hassle.
it's not a big deal but its bogus.
tis the season to be H A M M E R E D, fa, la, la...
#25
thanks Barnett.
I'm actually hammered right now.
at the moment, I'm leaning toward buying a set of ford springs to do the job and return the comp springs. single springs, not dual like these comp cam springs.
I plan to call comp Monday morning and try and sort it all out though.
I'm worried that my machine shop guy is just a machine shop guy and isn't aware of the potential that the inner spring may pull the stem seal off the top of the guide.
so picture this, for these comp springs, let's say the outer spring clears the raised part on the head, and the inner spring rests on the top of the raised part. is that a bad idea?
my machine shop guy says it will be fine, but all the evidence I have found says it needs to be milled flat. that's why I'm worried.
I think if my machine shop guy is just a machine shop guy and I give home the ford springs, he can't screw anything up.
#26
yeah I realize. the f cam was put in with the supercharger. supercharger is gone. somebody here recommended this one.
#27
hi,
don't worry about the outside of the spring. it need to be snug on the id with the raised platform and sit on top of the lower platform not on the outside of it. this is simple, if it had single springs then just measure the od of the raised platform on the retainer. it should be near the same as the platform on the head.
a machine shop guy cam screw up anything. spring set up is easy for those that know how but impossible for those that don't.
Again, as long as they end up close to what i suggested you are fine. you do not want or need closed pressure greater than 135. it will be hard on the valve train and beat your valves and valve seats to death.
if it is less than around 118 the valves might bounce as they close at high rpm. ohhh.
what did you not like about the 303 cam. the comp you listed is a good one but both need compression.
are ypou going to increase your compression as i suggested?
#28
hi,
don't wory about the outside of the spring. it need to be snug on the id with the raised platform and sit on top of the lower platform not on the pitside of it. this is simple, if it had single springs then just measire the od of the raised platform on the retainer. it should be near the same as the platform on the head.
Again, as llong as they end up close to what i suggested you are fine. you fo not want or need closed pressure greater than 135. it will be hard on the vakve train and beat your valves and valve seats to death.
#30
not with single springs, no way no how.
ok, i mentioned that if you shaved your heads your lock wire groove would not be deep enough so it will need to be re-emachined.
if milling the heads .025" from ORIG, removes the groove in the heads then either regroove them for the loc wire or just use the std gaskets but the thin ones i mentioned. i will get you the part number.
wrong, wrong, wrong, wrong, wrong, but i would buy hi perf ones.
